1998 GMC Jimmy Outside Temperature Gauge
1998 GMC JIMMY
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
LMAC
  • 4 POSTS
how can you reset the outside temperature gauge? My gauges seems to be reading about 40 degrees high.
Jun 24, 2009 at 9:56 AM
SWILLIAMS
  • 597 POSTS
It is self calibrating. If it always reads wrong the sensor has probably failed. There is a test procedure but you need the factory book to get it.
Jun 24, 2009 at 11:22 PM
LMAC
  • 4 POSTS
Generally whats involved to replace the gauge and whats the cost?
Just trying to see if its worth the exopense.
thanks for your input.
Jul 1, 2009 at 10:16 AM
SWILLIAMS
  • 597 POSTS
The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.
Jul 2, 2009 at 9:30 AM
LMAC
  • 4 POSTS
[quote:6cfee7f336="SWilliams"]The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.[/quote:6cfee7f336]
Thanks, you've been very helpfull
Jul 2, 2009 at 9:36 AM
