1998 GMC Jimmy air conditioning not working
1998 GMC JIMMY
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
NOEL1373
  • 7 POSTS
I recently had problems with my heater 'the vents send cold air,I fixed that problem by flushing system...,heater core ..etc.
now I can not shut off the heat off ,all the vents send only HOT,HOT air,, not cold, not warm..THE AIR CONDITIONING NOT WORK :( what happened? please,please help me :)[img:a2c10d20ed]http://www.2carpros.com/forum/automotive_pictures/150655_0c2c_3nueva_2.jpg[/img:a2c10d20ed]
Feb 18, 2008 at 10:12 PM
PEAR69
  • 1,482 POSTS
When you turn the air conditioning on--does the compressor kick in? It sounds like you have a blend door actuator that is not working,
Here is a guide to help you fix it.
Let me know how ti goes.
Feb 18, 2008 at 11:10 PM
NOEL1373
  • 7 POSTS
yes he does,with the air conditioning on,,off the vents send only hot air.
Feb 19, 2008 at 8:13 AM
PEAR69
  • 1,482 POSTS
Is your answer " yes the compressor kicks on and the vents blow hot air" ?
Feb 19, 2008 at 2:44 PM
NOEL1373
  • 7 POSTS
Hello , thank`s for help me,, yes the vents send only very hot air not warm not cold only hot air,.
the most cars with the air conditioning in off ,send cold air in winter time ,my truck send me only very hot air , does not matter if I put the a/c automatic control in cold or in warm,hot.
Feb 19, 2008 at 9:32 PM
PEAR69
  • 1,482 POSTS
I am assuming that the temperature selector switch is in the cold position and the blower only blows hot air--right?
Your heating and air conditioning systems are two totaly different systems. Your heating system relies on engine temperature to heat the coolant that flows through your heater core. Then the blower blows air right through the heater core and into the cars' cabin.
Your air conditioning system works a little different. There is a compressor that is driven by a belt mounted on the front of your motor. When you turn on the A/C switch this activates a clutch that is connected to the compressor. When activated (or kicked on) the compressor compresses refrigerant through the A/C system. To keep it simple--this refrigerant flows through the A/C system and extracts heat from the cars' cabin and replaces hot air with cold air.
The A/C system has no connection with the heating system. The pressure and amount of refrigerant ( R-134) is important. You need an A/C system pressure gauge to measure the R-134 in the system.
However it sounds like --to me-- that your problem is the temperature control switch. The switch I am talking about is right next to the fan speed switch. It has a setting that goes from "red" to "blue". Red meaning hotter and blue meaning colder. I think this switch may be broken...
Feb 20, 2008 at 12:52 AM
NOEL1373
  • 7 POSTS
YESSSS !!!! you think the switch was broken after flushing system..coolant.,heater core ..etc.
i will change the switch i be back :)
thank`s
Feb 20, 2008 at 8:04 AM
NOEL1373
  • 7 POSTS
Hello ,i changed temperature control switch , still sending hot air from te vents :( everything start when my heater not work,then i flush the system new coolant in the radiator etc. after i flush the system i get only hot air i move the control to (blue meaning colder ,the vents sends only hot air.
https://www.2carpros.com/forum/automotive_pictures/150655_DSC01063_1.jpg
Feb 21, 2008 at 9:20 PM
LALORENZO
  • 28 POSTS
Let me try to help,
The temperature switch controlls a vaccum or cable linked door that diverts air through either your heater core (for heat) the a/c evaporator (for cold) or both ( for warm air) . Look around the ventilation duct (the housing that runs from the blower to the vents) for any disconnected vaccum hose or cable that may come off during the time you serviced the heater core. I am almost certain thats the problem...larry
Feb 22, 2008 at 12:51 AM
