1997 GMC Jimmy Starter
1997 GMC JIMMY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
AMANDANEELEY
We try to turn the car over and nothing happens, we checked the starter, and it came back good, we got told to check the wires and my husband said they are good. So we are wondering what it could be?
Dec 24, 2009 at 10:48 AM
JDL
  • 16,098 POSTS
Welcome to the forum, check the crank fuse in the fuse box. Use a testlite, the circuit should be hot with the key in the start position.
There is also a starter relay, my info says it is located, center rear of engine compartment.
The purple wire at the starter solenoid, should be hot with the key in the start position. Always make sure the tranny is in park or neutral and the e-brake is set.
Dec 24, 2009 at 11:28 AM
