My entire electrical system is pulsating. Dash lights, headlights, fuel gauge, everything. The voltage meter on my dash shows the system charging at 16+ volts, but a handheld meter attached directly to the battery shows a steady 13.5 volts. OK, so my dash volt meter is inaccurate, but what would be causing the system to pulsate? The alternator checks out OK. I just had the fuel pump replaced. Could it be a bad ground somewhere? We also have had sub-zero temperatures which is hard on the battery, but it is very new and load tests OK. I'm baffled. . . Any ideas would be very appreciated.
Jan 9, 2010 at 4:40 PM
