1997 GMC Jimmy No fuel to injectors
1997 GMC JIMMY
100,121 MILES • 6 CYL • 4WD • AUTOMATIC
ABRUNO1
  • 4 POSTS
new fuel pump,nofuel going to injectors
Mar 1, 2010 at 9:21 AM
JDL
  • 16,098 POSTS
hi, did you check voltage and ground at fuel pump connector, before changing anything? For the pump motor, gray wire is voltage and black is ground. Check ecm B fuse, if no voltage. There should be a fuel pump test connector, under the hood, driver-side rear. A red wire with electrical connector, nothing plugged into it. If you use a jumper wire with inline fuse between battery and connector, the pump should run, don't need to use the key.
Mar 1, 2010 at 9:37 AM
ABRUNO1
  • 4 POSTS
I checked fuel pressure by using a jumper wire ,have 60lbs. of pressure.Checked injectors with a node tester and all injectors were getting power.Still no fuel to the injectors
Apr 4, 2010 at 10:23 AM
