1997 GMC Jimmy Driver Door does not latch
1997 GMC JIMMY
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
RJMDJM
My driver side door has been slipping. About 3 months ago The door latch sometimes would not move so that the latch could engage the holder to close the door. We was able to pull on the interior door handle and than manually move the latch in the door up. On Monday that Happened again but no we can't get the latch to engage to get the door to stay closed. Should we take the door panel off and see if the handle and latch system some way has come unattached. How do you remove the door panel
Dec 3, 2008 at 9:47 PM
Hi: Are the hinges good on the door? If so, there a few screws that will need removed and plastic pushin retainers that will pop off when you pull on them. Remove the panel and see if something is broken or unattached.
Dec 9, 2008 at 10:42 AM
SWILLIAMS
  • 597 POSTS
Sounds like the latch has either gotten dirt or rust in the latch hook area or the return spring has broken. Not uncommon on the drivers door.
Dec 14, 2008 at 8:43 PM
