1997 GMC Jimmy air conditioning not working
1997 GMC JIMMY
128,550 MILES • 6 CYL • 4WD • AUTOMATIC
KEITHNEUBECKER
hi everyone, i have a 1997 gmc jimmy with a 4.3 liter, 6 cylinder vortec engine. it has 128,500 miles on it. The problem is the air conditioning is not working. I recharged it and it worked for about 2 days then it wasent working again so im guessing there is a leak in the system somewhere. i used a black light to try to see where the leak was but i couldnt see anything. so number 1, where do these commonly leak at? and how can i tell where it is leaking from? thanks
Aug 26, 2008 at 6:56 PM
TECHCHOICEPARTS
The number one problem with your compressor, the GM HT6, mounted right on top of the engine, is case o-ring leak. The leak is usually located under the compressor, and is often missed because it's a hard place to get a light in. Once you remove the compressor though, you'll see it. Not a plug, but the link below has our write-up on the compressor, and the benefits of replacing it with a pinned unit.
The good news is that replacing that compressor is very easy, and fairly inexpensive.
Aug 27, 2008 at 9:52 AM
KEITHNEUBECKER
well the gm dealer replaced the commpresser when i bought it about a year ago so im thinking its in a different place.
Aug 27, 2008 at 12:25 PM
