1997 GMC Jimmy 4x4 does not work
1997 GMC JIMMY
152,000 MILES • 6 CYL • 4WD • AUTOMATIC
KYLE WALLEN
My 1997 GMC Jimmy's 4x4 drive does not work. The gear ratios will change correctly when the switch is on 4hi and 4lo. The front tires will not rotate at all.
Aug 30, 2008 at 5:18 PM
SWILLIAMS
  • 597 POSTS
Check the 4X4 actuator. It's mounted in the engine compartment under the battery. The battery may have leaked and the acid damaged the actuator.
Sep 6, 2008 at 2:18 PM
