1996 GMC Jimmy wont shift
1996 GMC JIMMY
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
POCJIMMY
my 96 jimmy will not shift gears unless you let off the gas. If you dont let off the gas it will buck. It wont go into overdrive unless u manually put it into drive then overdrive, then it drops back into drive. Any help is appreciated
Nov 16, 2009 at 11:03 AM
MICKEY-D
  • 304 POSTS
You could have a kickdown cable out of adjustment, or the trans modulator valve is bad or has low vacuum. I'm not sure which trans you have, some even have electric shift solenoids, but i think yours is a vacuum shift trans.
mickey-d
Dec 11, 2009 at 5:33 PM
