my 96 jimmy will not shift gears unless you let off the gas. If you dont let off the gas it will buck. It wont go into overdrive unless u manually put it into drive then overdrive, then it drops back into drive. Any help is appreciated
Nov 16, 2009 at 11:03 AM
