Sure I can help with that. You will want to use 14 gauge automative wire for the job, you can pick it up at any auto part store. You will also need the following :
push button starter switch
drill
wiring ends
crimping tool
Below are the basic steps for this temporary fix. Let me know if you need more assistance along the way.
Disconnect the vehicle battery negative cable from the battery.
Determine the best location for the push button switch. It should be in an area of the dashboard which can be easily reached by the driver.
Use an electric drill and a drill bit of sufficient size to drill a hole large enough to mount the switch. Check your switch for the size as it can vary from one brand to another.
Locate the starter solenoid which is built on to the starter itself.
Strip approximately 1/4 inch of insulation from one end of the 14 gauge wire. Using the crimping tool, crimp a solderless terminal (wire end) of the type necessary to fit the lugs on the back of your push button switch to the stripped end of this wire. Attach to the switch. Run the wire through the firewall and out to the solenoid.
Install a solderless terminal (wire end) which will fit the solenoid terminal to the wire and attach to the solenoid.
Fabricate a second wire and attach it to the switch. Connect the opposite end to a 12 volt power source or directly to the positive terminal of the vehicle battery.
Mount the switch in the dash board and reconnect the vehicle battery.
Now when you go to start the vehicle, you will still need your key. You only need to turn the key until the accessories come on and you hear the fuel pump kick in, do not attempt to crank the engine. Once the key is in this position, you will then push the starter button until the engine has fired up, then release the button. Now your engine should be up and running as normal.
Mar 24, 2019 at 11:42 AM
