1996 GMC Jimmy Shakes/Wobbles
1996 GMC JIMMY
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
YEP1
  • 10 POSTS
My 96' Jimmy right front tire wobbles. I have changed the rotor, and replaced the tires. This wobbling only occurs when I apply the brakes. The faster I drive, the more intense the wobble when I apply the brake. Any suggestions on what could be the problem? Also, my steering wheel does not shake/wobble.
May 2, 2009 at 6:11 AM
SERVICE WRITER
  • 9,123 POSTS
the pulsation may be coming from the rear. Do you have drums in the rear or disc?
May 2, 2009 at 8:16 AM
YEP1
  • 10 POSTS
Actually, it is the right front area, which has a rotor. It wobbles when I hit the brake pedal. I feel no movement from the rear.
May 2, 2009 at 9:43 AM
YEP1
  • 10 POSTS
Today, I bled all brakes, and it still pulsates in the right front area.
May 3, 2009 at 7:29 PM
SERVICE WRITER
  • 9,123 POSTS
Sorry for not getting back sooner. Probably have it solved by now.
Drive it and feel for any heat differences from side to side in the front. IF no heat difference then, I would check the rotor for bad run out. IF you don't have the tool, then swap the rotors side for side and see if the vibration feels that it moved or not.
Before you pull the rotors, shake down the wheel and make sure no movement is in the wheel bearing, ball joints or tie rod end.
May 27, 2009 at 5:35 AM
YEP1
  • 10 POSTS
Actually, I do not. What I have done is replaced the tie rod ends and the right idler arm. I bled all four wheels. I have not replaced the ball joints though. It only occurs when I apply the brakes. When I drive, I do not feel any pulsating/vibration. I'm at a lost.
May 31, 2009 at 7:53 PM
SERVICE WRITER
  • 9,123 POSTS
Take the rotors back and have them warranty them. When you put them on, be sure the hub surface is clean.
Make sure that the brake pads are able to move on the sliding surfaces and they are not worn abnormally. Any grooves in the spindle must be filled in or replaced or the pad will not move. USe a high quality disc brake caliper grease on the moving parts. IF the caliper piston is stiff to return in, then replace both calipers.
If it were mine, I would replace the pads regardless as a pulsation usually leaves the pads abnormal. Frankly, the only pad/rotor combination I recommend at this point are the Napa ultra premium rotors and the adaptive one pads.
Jun 1, 2009 at 6:04 AM
