Suspect vacuum leak. Check your vacuum lines to the vent doors under the dash, usually in the passenger footwell. There is a door that opens and closes to direct heat to where you tell it to go using the dash control. Also check for free movement of the door. If those all look ok, you probably have a bad dash control but vacuum leak is more typical.
Nov 22, 2008 at 10:21 AM
