1995 GMC Jimmy Sensor locations- Knock Sensor, TPS Sensor
1995 GMC JIMMY
105,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMES48843
My 95 Jimmy check engine light is on. The code readout says TPS sensor faulty, and Knock sensor faulty. I looked up on-line and see what they look like, but exactly where do I look for them? 4.3 Liter V6. FInal question- when I replace the sensors, does the light reset? Or is there a trick to resetting the light/clearing codes?
This is a 95, so it only has the older GM check engine light and the "key" type plug under the dash- not an OBD. Code is 21 and code 43.
Also- side note: I smell gas fumes- the mechanic says the fuel tank is rusty and leaking, but wants a thousand bucks to replace it and the fuel line. This is a snowplow truck only for the driveway. Gas milage is horrible, about 5- 8 MPG. Any ideas? Is it the leak? It runs as if it is running very rich.
thanks in advance.
Jan 27, 2008 at 10:46 PM
MERLIN2021
  • 17,250 POSTS
Knock sensors are J1 and J2 TPS is C, to reset codes remove the ECM fuse or neg(-) battery cable for 10 seconds...If you have fuel leaks and you have TBI you will be smelling and pumping gas out of any holes! Fix it b4 it burns!
https://www.2carpros.com/forum/automotive_pictures/62217_95KnockTBI_1.jpg
Jan 28, 2008 at 9:28 AM
