1995 GMC Jimmy Runs rough except on flat road
1995 GMC JIMMY
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRUMAR59
  • 5 POSTS
My truck seems to run fairly smooth while driving a constant speed, but if I accelerate or begin slowing down, the engine begins to run rough. Also, as my transmission shifts through gears, the engine roughness changes, almost like it runs rough only at certain load/rpm/gear combinations. I hear that if it runs rough ALL of the time, it's probably a timing issue. In this case, would my problem have more to do with spark plugs/wires/distributors than timing? Or something else? Thanks.
May 12, 2008 at 12:28 PM
HOTBLAZER
Do you have a VORTEC V-6 engine with fuel injection? If so, it sounds like you may be having a proplem with your CPI valve, part of the fuel injection system of a VORTEC engine. NOT AN EASY FIX. If you have a different engine, I don't know what to tell you.
May 12, 2008 at 12:36 PM
BRUMAR59
  • 5 POSTS
Yes, I do have a VORTEC V-6. CPI valve? I'll have to look that up. Thanks!
May 12, 2008 at 12:45 PM
