1995 GMC Jimmy rough idle
1995 GMC JIMMY
BRETLEE.DIONISIO88
Engine Performance problem
1995 GMC Jimmy 6 cyl Four Wheel Drive Automatic
rough idle in R & D........ijust changed the distrobuter rotor,ignition coil,spark plug/wire....PLS help...need answer....thanks...
Jan 22, 2010 at 4:41 PM
Try cleaning out the idle air control valve and EGR and PCV valves and test the TPS and MAP sensors to include a fuel pressure check
Jan 22, 2010 at 5:38 PM
