I recently had to remove the engine and transmission to replace leaking freeze plugs. after re installing engine, it wont start...fuel is getting to the schrader valve on the fule line at manifold and it will start with ether, but will not start and run. It acts like no fuel. Is there a special procedure for priming the fuel system after removing engine ? I can push down the schrader valve and crank engine and gas flows out of valve. If dirt got into fuel lines when they came out with engine, how do I clean system ?
Ran fine before removing engine....
Can the TPS cause it if bad ?
HELP !!
HELP !!
Oct 20, 2008 at 8:46 AM
