1995 GMC Jimmy ignition key
1995 GMC JIMMY
122,400 MILES • 6 CYL • 2WD • AUTOMATIC
GROG
I put the key in the ignition and it won`t turn it`s like someone switched my keys
Jan 1, 2008 at 9:10 AM
BLACKOP555
  • 10,386 POSTS
first try another key, and secondly is your antitheft system functioning properly? try some graphite lock lube sprayed in the cylinder and insert the key and remove several times and tap on the cylinder, if this dont work you may have to drill it out and replace.
Jan 1, 2008 at 12:11 PM
