1995 GMC Jimmy 6 cyl Four Wheel Drive Automatic
when i hit the gas pedal it has a miss fire and rpm guage bounces up and down goes crazy and than backfires at high rpm. almost sounds like egr valve is open at idle. the rpm gauge is still going crazy at idle but engine lite does not come on and has good fuel pressure 63psi the plugs, wires, cap, rotor ,coil, ingition module, tps sensor , and cam sensor are all new any ideas
Apr 29, 2008 at 2:20 PM
