1995 GMC Jimmy Electrical
1995 GMC JIMMY
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
DARRENM04
HI I have a 1995 GMC Jimmy and recently the fan stopped working for my AC and Heat, I had the fan replaced and now I have had a electrical fire behind the dash (where the radio and switch for fan is) I tore it apart and found a burnt ground wire. I corrected the problem or so I though and last night I had a similar electrical problem. The wires are all fine behind the dash, but radio will not work. I realize there has to be a short somewhere, but where? Also, would it be safe to assume that this was all caused by a faulty install on the fan? Any input would greatly help. Thanks Darren
Feb 6, 2008 at 8:40 AM
DARRENM04
So I have traced all the wires back form the dash, and everything seems to be conected properly! The fan is working as it should but I have no radio installed for I am now thinking that was the root of the problem. Any Ideas?
Thanks.
Feb 7, 2008 at 9:47 AM
