My Jimmy has been overheating when idling. It stays at normal operating termperatures when driving down the highway. I found that it is leaking right above what I believe is where the oil cooler line meets the radiator. At times, the coolant is literally spraying out of the line fitting. I tried a radiator seal solution, but this did not help much. The coolant only leaks out when the engine is running at hot termperature. I don't believe there is any oil leaking from that area, but I am failry certain the leak is coming from the oil cooler line fitting. Is this somewhat of an easy fix, as in, is it simply a gasket or something similiar? Something I can do in my garage or under a shady tree?
Jul 12, 2010 at 9:58 AM
