1995 GMC Jimmy antifreeze & soot in egr valve?
1995 GMC JIMMY
DOEDGI
  • 4 POSTS
1995 GMC Jimmy 6 cyl 124000 miles
Why is there antifreeze in the EGR valve? I was told that the head gasket is leaking...could that be the problem?
Apr 27, 2009 at 3:52 PM
DOEDGI
  • 4 POSTS
Please send answer to my email address, thank you.
Don
Apr 27, 2009 at 3:54 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ccb4f58597="doedgi"]1995 GMC Jimmy 6 cyl 124000 miles
Why is there antifreeze in the EGR valve? I was told that the head gasket is leaking...could that be the problem?[/quote:ccb4f58597]
Most likely it is a blown Intake Gasket.
Apr 27, 2009 at 3:56 PM
DOEDGI
  • 4 POSTS
Is this a minor repair or big bucks?
Apr 27, 2009 at 8:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:dec3a34cd7="doedgi"]Is this a minor repair or big bucks?[/quote:dec3a34cd7]
Well, The top of the engine has to come off and most of the front of the engine. So, it could run as much as $1,000. Maybe more depending on labe rate in your area.
Apr 27, 2009 at 10:01 PM
DOEDGI
  • 4 POSTS
When you are driving there is a sound coming from the rear end which sounds similiar to a wheel bearing that is getting worn. I was told that it is a normal sound that goes with Hyundais....is that true or am I being fed a crock? The car has been "certified" but has this problem been addressed when they checked it over?
May 26, 2009 at 12:38 PM
CFERRY1
  • 29 POSTS
Yes, This is a common problem if the engine has over heated And / Or GM does have a defect with the Design or Manufactured Assembly placement of Intake Gasket Sealant on the corner or one side.
You may have a local repair shop look up this manufacturer suggested corrective action concerning this Intake Gasket !
It is a Medium Big job !
May 26, 2009 at 1:39 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ac5765ba68="doedgi"]When you are driving there is a sound coming from the rear end which sounds similiar to a wheel bearing that is getting worn. I was told that it is a normal sound that goes with Hyundais....is that true or am I being fed a crock? The car has been "certified" but has this problem been addressed when they checked it over?[/quote:ac5765ba68]
I am not sure but will check on it and let you know.
Also Please if you have other questions on other Makes and Modeld post them in the appropriate catagory.
May 26, 2009 at 8:13 PM
