1994 GMC Jimmy vacuum line diagram for 4wd and trans on1994
1994 GMC JIMMY
TONYRICC
1994 GMC Jimmy 6 cyl Four Wheel Drive Automatic
where can i find a vacuum line diagram for the 1994 gmc jimmy for the 4wd from vac switch to vac off engine?
Oct 26, 2008 at 8:29 PM
SWILLIAMS
  • 597 POSTS
The vacuum connection for the actuator comes off a multi outlet connector located near the distributor. From there it drops down to the switch on the transfer case. Then it goes to the front axle disconnect. On the transfer case switch you will find 3 lines. two are vacuum and the third is a vent.
Oct 30, 2008 at 11:08 AM
