1994 GMC Jimmy ticking noise
1994 GMC JIMMY
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRSFROGG
My father and husband recently replaced the manifold intake gaskets. While doing that found the the EGR valve needed cleaned and the valve needed replaced. We had to take it to the shop to get this done. After my father had replaced the gaskets a ticking noise which can be heard very well underneath the car started. My father automatically said it was a lifter. He said that while messing with the gaskets and the EGR system that a lifter may have gotten messed up. But the guy at the shop claims it is the flywheel. It is just odd that the ticking noise started until my dad was changing things. I guess my question is does this sound like a flywheel? And if so, how long can it go before messing with the tranmission?
Aug 13, 2008 at 12:23 PM
KLSHIEL
  • 163 POSTS
A lifter should be louder at the top of the engine. The flywheel is just a big metal plate. The purpose of the flywheel is to take vibration out of the engine. It also is used to put a toothed ring around that the starter engages and to bolt up to the transmission. Nothing exept major damage or loose bolts should be able to cause this to make any noise. Loose bolts would need to be fixed before more damage occures. I think more trouble shooting should be done to find the source of the problem
Aug 13, 2008 at 12:42 PM
