1994 GMC Jimmy engine hesitation at low speed
1994 GMC JIMMY
SHANES76
Engine Performance problem
1994 GMC Jimmy 6 cyl Four Wheel Drive Automatic
I have a 4.3 Vortec with VIN"W" and it like right off idle and a low speed until it shifts into 2nd there is a hesitation and while coasting the idle surges- it doesnt stall out though- it has a new MAP sensor, intake air temperature sensor(got a SES for it) But if I drive it for about an hour on the highway and stop at a light and take off sometimes it wont hestitate until a few stops, it was really bad but I pulled the IAC valve and cleaned it, check EGR which one side was loose so I cleaned it - reinstalled with new gasket, new PCV valve. I am getting a SES for 35 (IAC valve and 43(knock sensor) the knock sensor is not hooked up due to a broken plug would these 2 items cause my problems? It starts great, idles great- might have a little pop every once in a while
Jan 5, 2010 at 7:33 AM
Check and test the following below:
Oxygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Coil and Rotor
Jan 5, 2010 at 11:34 PM
SHANES76
It has a new map sensor, new IAT sensor, I just cleaned the IAC valve and EGR but since I cleaned those it has gotten alot worse in the last 2 days, Im getting a code for the IAC sensor, it sounds like a poping coming out of the exhaust, I know its not the converter cause I dont have one, this engine doesnt have a MAF sensor, and it seems to do it worse once it warms up, but if I drive for a while at a steady speed and stop, sometimes its ok and others its not
Jan 6, 2010 at 5:20 AM
