1994 GMC Jimmy crank shaft sensor
1994 GMC JIMMY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
CRYSTALANDKEVIN1
  • 6 POSTS
where is the crank shaft sensor located in a 1994 GMC Jimmy?
Mar 25, 2008 at 3:29 PM
Dunno if you have one but check at the harmonic balancer/vibration damper/pulley
Mar 25, 2008 at 3:41 PM
CRYSTALANDKEVIN1
  • 6 POSTS
i have one and i bought a new one because i had a few suggestions it could be that, but i cant find the old one. i replaced the map sensor and throttle position sensor, still not that.
Mar 25, 2008 at 3:48 PM
Look on the big pulley on the bottom of the engine-I've checked it thru the eautorepair.net non was listed-try calling the dealer
Mar 25, 2008 at 5:37 PM
