1991 GMC Jimmy not getting fuel
1991 GMC JIMMY
BIGGUN1974
Engine Mechanical problem
1991 GMC Jimmy 6 cyl Two Wheel Drive Automatic
i am not getting fuel on my 1991 gmc s-15 jimmy
Sep 14, 2008 at 12:57 PM
Do you hear the fuel pump come on for 2secs? If so check the fuel pressure and comeback with the readings this is where we start
Sep 14, 2008 at 1:04 PM
BIGGUN1974
do not here fuel pump run
Sep 14, 2008 at 1:05 PM
Could be the fuel pump fuse/fuel pump relay or just the fuel pump itself has given up-
Sep 14, 2008 at 2:10 PM
RAWR818
Im Having the same problem. Changed the pump, relay and fuses. The fuel pump is only getting 8.5Volts. Im guessing its something electrical but what?
-Raul
Oct 6, 2008 at 2:55 PM
Direct battery power to the fuel pump connector gray wire and see what happens
Oct 6, 2008 at 4:22 PM
RAWR818
[i've treied that, the pump stays on even when the car is off.
Oct 23, 2008 at 12:44 PM
