turns over but won't start
1989 GMC JIMMY
75,000 MILES • V8 • 4WD • AUTOMATIC
TALLCANADIAN
  • 4 POSTS
i have a full size jimmy with a 350 engine. the motor turns over, there is spark at the plug. the fuel pump does make it's usual sound when turn on the key. i even poured gas straight down the throttle bottle but it still won't catch. it's -16 celcius here but it's been colder, so i can't see it having any ice in the gas. i used it sunday but this morning it won't fire up. any help would be appreciated.
Jan 26, 2009 at 4:50 PM
BMRFIXIT
  • 19,053 POSTS
is it possible fouled spark plugs
I would remove and replace the spark plugs
bad gas !!
Jan 26, 2009 at 5:00 PM
TALLCANADIAN
  • 4 POSTS
spark plugs are new. wires are not new but seem to be okay. if the fuel pump was bad would it still make it's usual hum sound?. also i noticed when i drove it saturday it did stumble a bit once but was fine the rest of the day. thanks.
Jan 26, 2009 at 5:06 PM
BMRFIXIT
  • 19,053 POSTS
It is possible to be bad fuel pump
yes it is possible for it to be working and not giving out the pressure needed
see the thing is when put gas down the throttle if it was a fuel issue it should ve starter a bit
but in your case it didnt
you said you have spark
if the spark weak reaching the plugs on a cold day they will foul
reason for me to remove at least one and check
need to have a strong spark at the wire spark plug side
check for a fouled plugs
make sure u have the air filter and cover on
hold gas paddle all the way down and crank the engine to start
good luck
Jan 26, 2009 at 6:04 PM
TALLCANADIAN
  • 4 POSTS
fooled around with the truck a bit. it is getting gas and spark. although i have no way of measuring either. i took the distributor cap off just because, and the rotor and cap were well worn, corroded. i replaced those but still won't start. i also took all the plugs out and check them. they are all burning the same and are not fouled or bad. any other help would be appreciated.
Feb 1, 2009 at 6:52 AM
TALLCANADIAN
  • 4 POSTS
i've been trying to check my timing chain but when i bring the timing marks together i notice that the distributor does not point at number 1 but looks like number 3. is this the answer that i'm looking for? timing chain? thanks for the any help,
Feb 8, 2009 at 11:56 AM
BMRFIXIT
  • 19,053 POSTS
It should be close to # 1 try and turn the distributor and or pull it out and check drive gear if timing of, you should had a wrong compression readings
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_187.jpg
Feb 9, 2009 at 6:13 AM
THOMAS EDISON
  • 5 POSTS
I'm having the same issue with my 88 same engine same issue did you ever find the problem ????
May 20, 2019 at 12:01 PM
If you turn the key on without cranking the engine over can you hear the fuel pump run in the tank for five seconds? This guide can help:
May 20, 2019 at 12:57 PM
