how do i drop the fuel tank to get to my fuel pump
Dec 30, 2008 at 1:54 PM
BILLYMAC
CERTIFIED EXPERT
if you have a shield over the tank remove it put jack under tank remove fill tube from tank.and vent tube remove two 15 mm bolts for tank straps lower tank disconnect fuel lines and harness lower tank remove lock ring good luck billymac
