front passenger side makes a squealing noise when the car is driven
2005 GMC ENVOY
JBENDER961
Wheel on front passenger side makes a squealing noise when the car is driven. Brakes do not squeak or grind when the car brakes is pushed down. Is this a rotor issue, or something with the bearings?
Jun 29, 2009 at 12:56 PM
Yes. This is most likely the pad and rotor squeaking. Here are guides that will help with this:
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
https://www.youtube.com/watch?v=1dB17cMwSOQ
I would recommend changing the pads and rotors and below you will find the process from the manual. Please let us know if you have other questions. Thanks
Apr 25, 2021 at 6:53 PM
