2004 GMC Envoy rear window
2004 GMC ENVOY
166,000 MILES • 6 CYL • 4WD • AUTOMATIC
XBIRDIE14
I have a 2004 gmc envoy xuv. It has a rear tailgate with a sliding rear window. I am trying to replace the rear window regulator in the tailgate. the regulator is broken. My question is how can i get the tailgate to open.
Feb 2, 2010 at 11:19 AM
2CARPRO JACK
  • 11,533 POSTS
Im not sure I understand. Is the tailgate latch broken as well as the reg for the window? Or the gate wont release due to window position? If the latter, you will need to remove the interior panel to access the latch and manually release it.Be very careful not to break the glass
Feb 4, 2010 at 7:45 AM
XBIRDIE14
if the regulator is broken you cant obtain proper window location for the tailgate switch to activate and allow the gate to open. Is there a way to manually open the tailgate and if there is what is it?
Feb 4, 2010 at 8:15 AM
2CARPRO JACK
  • 11,533 POSTS
You will have to remove the inner panel on the tailgate and manually unlatch it
Feb 4, 2010 at 11:47 AM
