2002 GMC Envoy trani doesnt shift
2002 GMC ENVOY
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENOYER23
was told trani had "small leak" approx 3wks ago. 4 days ago while driving approx 35-4-mph, engine began to "drag" and vehicle wouldnot accel.Pulled off road, check fluid level was normal. Drove vehicle approx 5mph and then parked it. Burning smell noted afterwards.Do I need to replace trani? Last fluid and filter change was @100,000mi.
Feb 20, 2010 at 4:29 PM
HMAC300
  • 48,601 POSTS
have a trans shop look at this. a burning smell can't be good. Unfortunately wen you get around the 100,000 mile mark fluid should only be added as new fluid eats the glue off the clutches inside the trans. You may need a rebuild.
Feb 28, 2010 at 11:00 AM
