2002 GMC Envoy noise going over bumps
2002 GMC ENVOY
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
GROQUE
As the rear tires of the vehicle passes over bumps 30 mph or so; I hear a rattle/ thumping type noise coming under the left rear passenger side of the vehicle. I jacked the rear off the ground; check tire rotation, side to side movement, bolts, nuts and schock security; found nothing. Shocked vehicle back and forth and bounced on the bumper; found nothing.
Can you point me in the correct direction of what can be the issue causing the noise???
Greg
Jun 8, 2009 at 8:33 PM
SERVICE WRITER
  • 9,123 POSTS
The first two places I would look would be the bushings at the sway bar to frame and then the stab link.
https://www.2carpros.com/forum/automotive_pictures/30961_env1_1.jpg
Grab the sway bar close to the bushing and agressively push pull.
https://www.2carpros.com/forum/automotive_pictures/30961_env2_1.jpg
Same on the stab links. Alos be sure it in nothing on the interior laying inside any compartment and be sure the spare tire has no movement.
Jun 9, 2009 at 5:10 AM
