cabolovers,
I'm just wondering if you ever found a fix for your headlights? Suddenly my 2003 Envoy started doing the same thing. The highbeams seem to work fine and so does the front corner lights and read tail lights. I'm not sure if my normal daytime running lights work since I just found this problem tonight.
I checked the fuses and Headlamp Driver Module(inside fuse panel) and everything seems fine. I'm thinking the headlamp switch might be the problem but I don't think there is any way of testing it and from what I've found on the internet, it's not that cheap of a part to purchase.
Any results you may have come up with would be helpful.
Thanks
Oct 7, 2010 at 8:13 PM
