Hello
Thanks for the additional info.....however, the only thing I show is a Delphi system and Philips. Both are High Intensity Discharge (HID) which would refer to the xenon type. I also have those two for headlamp starter/arc tube replacement as well.
I will attach all 4 - Lord willing it is the one you need.
"¢ Headlamp Replace - High Intensity Discharge (HID) (Delphi)
REMOVAL PROCEDURE
CAUTION:
The high Intensity discharge system produces high voltage and current. To reduce the risk of severe shocks and burns:
Never open the high intensity discharge system ballast or the arc tube assembly starter.
Never probe between the high intensity discharge system ballast output connector and the arc tube assembly.
The high intensity discharge system produces high voltage and current. In order to reduce the risk of severe shocks and burns, the battery negative cable must be disconnected any time service work is being performed on or around the high intensity discharge system.
NOTE: Avoid touching the bulb or letting the bulb come in contact with anything damp. Oil from your skin or moisture on the bulb can cause the bulb to explode when the bulb is turned on. If either comes in contact with the bulb, clean the bulb with alcohol or a suitable degreaser and wipe the bulb dry.
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
Remove the battery negative cable.
Remove the radiator grille from the vehicle.
Remove the front bumper assembly from the vehicle.
Remove the starter cable retainers from the headlamp ballast.
Remove the starter cable from the headlamp ballast.
Remove the headlamp retainers by pulling up and outward.
Disconnect the electrical connections and bulb(s) from the headlamp housing.
Remove the headlamp mounting bracket retainers.
Remove the headlamp mounting bracket from the headlamp housing.
On a bench, remove the arc tube with starter from the headlamp housing.
INSTALLATION PROCEDURE
On a bench, assemble the arc tube with starter to the headlamp.
Install the headlamp mounting bracket to the headlamp housing. NOTE: Refer to Fastener Notice in Service Precautions.
Install the headlamp mounting bracket retainers. Tighten
Tighten the headlamp mounting bracket flange nut to 5 N.m (45 lb in) .
Tighten the headlamp mounting bracket bolts to 1.24 N.m (11 lb in) .
Connect the electrical connections and bulb(s) to the headlamp housing. IMPORTANT: Ensure that the lower retaining tabs are seated for proper headlamp housing retention.
Install the headlamp to the vehicle.
Install the headlamp retainers by pushing down and inward.
Install the starter cable retainers to the headlamp ballast.
Install the starter cable to the headlamp ballast. Tighten Tighten the starter cable screws to 0.7 N.m (6 lb in) .
Install the front bumper assembly to the vehicle.
Install the radiator grille to the vehicle.
Install the battery negative cable.
"¢ HID Headlamp Starter/Arc Tube Replacement (Delphi)
REMOVAL PROCEDURE
CAUTION:
The high intensity discharge system produces high voltage and current. To reduce the risk of severe shocks and burns:
NOTE: When removing or replacing the arc tube, the arc tube must not contact the side of the headlamp housing or the bulb shield. Damage to the arc tube may result.
Disconnect the battery negative cable.
Remove the headlamp.
Remove the arc tube with starter retaining screws from the headlamp housing.
Remove the arc tube with starter from the headlamp housing.
Remove and retain the spiral Electromagnetic Interference (EMI) shield from the headlamp housing.
Install the spiral Electromagnetic Interference (EMI) shield to the headlamp housing. IMPORTANT: The headlamp starter must be held perfectly straight to the headlamp housing, apply pressure downward to compress the spiral electromagnetic interference shield with the headlamp starter as the three screws are replaced. The headlamp starter and arc tube assembly also has a tendency to tilt to one side because of the spiral electromagnetic interference shield.
Install the headlamp starter assembly to the headlamp. Ensure that the alignment notch (1) and tab (2) are lined up. NOTE:
The correct tightening sequence must be followed. If the correct sequence is not followed, the headlamp components may warp and cause premature failure of the system.
IMPORTANT: Follow the correct tightening sequence. Use GM P/N 12346067 or Loctite(R) 380/410 on these fasteners or in the headlamp housing screw holes.
Install the starter/arc tube retaining screws to the headlamp housing. Tighten
3.1. Tighten the starter/arc tube screws to 0.5 N.m (4.5 lb in) on the first pass.
3.2. Tighten the starter/arc tube screws to 1 N.m (9 lb in) on the second pass.
IMPORTANT: The starter cable routing from the starter/arc tube to the ballast is between the headlamp mounting bracket and the back of the headlamp housing. The starter cable must be routed between the vertical adjuster and the center pivot in order to provide proper clearance.
Connect the battery negative cable.
"¢ Headlamp Replace - High Intensity Discharge (HID) (Philips)
REMOVAL PROCEDURE
CAUTION:
Remove the starter cable retaining screws and cover from the headlamp ballast.
Remove the retaining clip from the starter cable connector.
Install the starter cable connector to the ballast. IMPORTANT: The arc tube will not energize if the retaining clip is removed or improperly installed.
Install the retaining clip to the starter cable connector.
Install the starter cable retaining screws and cover to the headlamp ballast. Tighten Tighten the starter cable screws to 0.7 N.m (6 lb in) .
"¢ HID Headlamp Starter/Arc Tube Replacement (Philips)
Nov 5, 2008 at 5:57 PM
