2000 GMC Envoy headlight
2000 GMC ENVOY
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
BSPAMC
Need to resolve the issue of replacing the headlight issue that some crazy engineer developed for GMC. The cost is way to high for a low beam headlight. Knowing that the other one is probably going out also. Help!
Jan 10, 2009 at 9:20 PM
MMPRINCE4000
  • 8,548 POSTS
Are they burning out? what problem (other than cost) are you having.
When you replace the Halogen bulb, it is important NOT to touch the bulb glass with your bare hands, the oils in your skin will cause a hot spot which will cause the bulb to blow prematurely.
Jan 17, 2009 at 9:11 AM
