2007 GMC Canyon change oil light reset
2007 GMC CANYON
STEWARTWBC
Computer problem
2007 GMC Canyon 4 cyl Two Wheel Drive 66000 miles
How do I reset the change oil light
Jan 2, 2010 at 1:43 PM
BRIAN 1
  • 1,030 POSTS
Turn the ignition to RUN with the engine OFF.
Press and release the reset stem in the lower center of the instrument panel (I/P) cluster until the OIL LIFE message is displayed.
Once the alternating OIL LIFE and RESET messages appears in the display, press and hold the reset stem until several beeps sound. This confirms the OIL LIFE system has been reset.
Turn the key to lock.
If the CHANGE OIL message comes back on when you start the engine, the ENGINE OIL LIFE system has not reset. Repeat the procedure.all this info is located in your owners manual.
Jan 2, 2010 at 5:14 PM
