2006 GMC Canyon Starting and Shutting off problem.
2006 GMC CANYON
25,000 MILES • 4 CYL • 2WD • MANUAL
LEANNA97754
My truck has a few problems. First of all, starting the truck there is a hesatation or delay of about 3 seconds. About 75 % of the time when I turn the key all the way to the off position it doesn't shut off. I have to let it die. My other problem I am having which I am not sure if it is related is something is drawing power from my battery. So half the time it is dead when I go to start it. I purchased a brand new battery so I know it is not that. I had installed a after market stereo, amp, and speaker box, But when I started having this power problem I uninstalled all of it but I continue to have these problems.
Thank you!
Nov 12, 2008 at 12:19 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like a faulty ignition switch causing both your problems. sounds like ignition power is staying on slightly killing battery and staying on a little causing it to not to shut off and not fully engaging causing the extended crank. too many problems that all lead to ignition switch so i feel confident that its your problem. hope this helps
Nov 12, 2008 at 5:08 PM
