2005 GMC Canyon rear window leaking
2005 GMC CANYON
25,121 MILES • 6 CYL • 4WD • AUTOMATIC
FRANKD547
This is a 5 cylinder truck. Just discovered rear window is leaking. Research says it is probably third brake light assembly that has warped and is leaking. Can I replace this myself? Do I need instructions? Thank you
Dec 29, 2008 at 3:11 PM
BRIAN 1
  • 1,030 POSTS
you might want to run a hose over area to make sure that is the problem.take the headliner down and make sure.you correct the leak with seam sealer.post back with any other questions.
Dec 29, 2008 at 4:11 PM
