I have high beam lamps, but not low beam. I thought it was the lamps themselves, but unplugged the lamp and turned on the light switch and checked current and found nothing, but I turned on te high beams and stuck the wire with the tester and had current. Are there any other fuses or switches that may be burnt out that I can check without first changing dimmer switch?
Jan 26, 2010 at 1:56 PM
