1994 GMC C3500 STUCK IN 4 WHEEL DRIVE
1994 GMC C3500
108,000 MILES • V8 • 4WD • AUTOMATIC
LUTZ
My 94 GMC dually is stuck in 4 high and 4 low and even neutral but it wont go in to 2 high.Any suggestions? also if I drive the truck with the front drive shaft removed will it mess up my auto-hubs or anything else? currently i'm driving it in 4 high its my only transportation is this bad?
Dec 6, 2007 at 8:24 PM
BLACKOP555
  • 10,386 POSTS
i wouldnt drive with the shaft removed. try this. go forward and stop hard and then while holding the brakes down put the shifter in neutral and then try to shift it to neutral, if nothing release the brakes and try to shift it. try having a friend rocking it to remove it.
Dec 6, 2007 at 8:49 PM
