1992 GMC C3500 transmission removal
1992 GMC C3500
250,000 MILES • V8 • 4WD • AUTOMATIC
ALLENBOMBER
I'm trying to remove the auto trans in my 92 Sierra 3500, but there's a cross member sandwiched between the frame rails which contains the trans mount. I don't think I can get the trans out without removing this cross member, but I can't get it out from between the rails. Sorta looks like this: [----] I've already removed all the hardware including the trans mount hardware so it is free sliding, but there's not enough room to rotate or lift. What can I do? All my Chilton manual says is "Remove any skid plates that would interfere with transmission removal." (not helpful)
Nov 19, 2009 at 4:10 PM
AJVANDYKE
  • 36 POSTS
Getting those out can be kind of a pain especially if you're flat backing the transmission. Heres what you can do to get it out...
First get a jack and lift the transmission up by the front of the trans oil pan but make sure you use a peice of a 2x4 between the jack and the trans pan so you don't damage the pan. (Lift trans about an inch higher then where it would normally sit with the mount and the cross member bolted in. Where you have enough room that you could even slide the cross member under the trans pan) Then with the weight of the trans suported take the drivers side of the cross member and slide it forward. Then take the passenger side of crossmember and slide it toward the back of the truck. So if you're looking from the ground up to the cross member you are turning the whole cross member counter clockwise. So just keep sliding it out that way untill the crossmember comes out. This can be frustrating so try and stay cool and let me know if you have anymore questions.
Nov 19, 2009 at 4:39 PM
ALLENBOMBER
I appreciate it. I've been trying this, but maybe it needs some persuasion (hammer)
Nov 19, 2009 at 6:01 PM
