1991 GMC C3500 Transmission cooling lines
1991 GMC C3500
120,000 MILES • V8 • 2WD • AUTOMATIC
LBETHARDS
I need to replace the radiator, but cannot budge the threaded cooling line connectors going into the radiator. Can I cut out a section of the steel tubing and use rubber tubing and clamps after replacing the radiator? Or are those lines under high pressure?
Jun 24, 2008 at 10:10 AM
MERLIN2021
  • 17,250 POSTS
There is a wrench called "flare nut" go and get it and then slap it hard with the palm of your hand....mechanics do it everyday! If a new radiator is going in, don't be afraid to carefully heat the nut..quickly!
Jun 24, 2008 at 5:55 PM
