[quote:bad8415337="Tim Kelley"]Transmission problem
1984 GMC C3500 V8 Two Wheel Drive Automatic 186000 miles
I have a leak in my transmission. it is from a small hole on the top and toward the back of the transmission it looks as though their is suppose to be some sort of plastic plug or something in there it is slightly smaller around than a #2 pencil[/quote:bad8415337]
Hi Tim,
Yes, there is suppose to be a plastic vent plug there. You may need to go to the dealer and see if they can get a new one for you. But, I don't think it should be leaking unless the tranny is over full. None the less there needs to be a vent plug so that water and debri doesn't get into the tranny. And No you cannot just plug the hole. If not vented it will cause tranny problems because it won't be able to breathe.
Feb 21, 2009 at 6:12 PM
