I bought 1978 RV on a GMC 3500 chassis. It starts good and runs great all the way up to speed, UNTIL it reaches operating temperature. Then it has a huge miss. The more gas the worse it gets. If you bury the 4 bbl. it would die if it wern't moving. It is a 454 cid., with a large quadrajet. I have changed all of the following. Fuel pump, fuel filter, air filter, dist. cap and rotor, coil, the module in the dist., spark plugs. Watching the choke, it seems to be working fine. It looks like there is an EGR valve on the intake. If it is bad, could it cause this problem? I'M not up to speed on smog equipment. Suggestions needed. Thanks Edward
Aug 11, 2008 at 2:05 PM
