Which switch button, are you talking about? the climate control unit in your dash? or the pressure control switch Under the hood?
Oct 28, 2009 at 11:57 PM
LONGORIAVIC1
MEMBER
The climate control switch it doesn't turn to the different settings and I don't know how to get to the underside of it.
Oct 29, 2009 at 12:12 AM
DR LOOT
CERTIFIED EXPERT
to gain access to your climate control, listen very closely, . You're dash is like a snap together toy, with your fingers grabbed the trim that goes around your instruments, Your radio and your climate control pull it straight out (you may need a butter knife to get underneath the trim), once you have removed the trim you will gain access to your climate control unit and your radio and everything else.
