1999 GMC C2500 CRANK POSITION SENSOR
1999 GMC C2500
130,000 MILES • V8 • 2WD • AUTOMATIC
BLGOBER1
i have taken my truck to the shop because it would turn over but not start. it was running fine and then it started to back fire and surge. sometimes it would start now not at all. the shop said it they pulled a code of, i believe 336 they said it would need a crank position sensor. i paid them diag fee and replace the part myself. it still is doing the same thing.i have 12v at the sensor, i have 12v into the coil and out of the coil with the key on. i replaced the cap and rotor because of some corrosion on the coil wire connection. the plugs are new the wires are new. you can hear the fuel pump come on. i put some gas into the intake to see if it would try to start. still same issue. please help!
Oct 25, 2008 at 6:03 PM
Hi:
Are you getting spark to the plugs?
Dec 15, 2008 at 7:05 PM
BLGOBER1
no spark to plugs. replaced the pick up coil and had the module tested it tested good with a load. tried a new coil still same issue. i thinking of taking it to another shop but im not familiar with any in my area.
Dec 15, 2008 at 7:37 PM
hi:
If you have power to the coil, the problem must be in the distributor. Are you getting spark from the coil? Also, remove the dist cap and have someone crank the engine to make sure the rotor is turning.
Dec 16, 2008 at 3:12 PM
BLGOBER1
hey thanks i had a wrecker pick it up today to take it to the shop. i just dont have time to mess with it anymore. thanks again for your help.
Dec 16, 2008 at 6:45 PM
Hi:
Sorry I wasn't able to get to you quicker. Let me know what they find.
Dec 16, 2008 at 7:28 PM
