I have a code 1351 that only shows up after running vehicle to operating temperature-let it set for 1 hour and then it will not start on first hit of ignition key. On second hit of key,it starts right up. Or if you let it set and cool all night it will start right up. I have replaced distributor cap, rotor,i.c.m. module, coil,crankshaft sensor,camshaft sensor,plugs and wires. I have also replaced the e.c.m with a remanufactured one flashed from auto zone! What else could it be? Thank you.
Apr 22, 2009 at 10:14 AM
