you have to do these in sequence,start at 22 ft. lbs. then go back, short bolts 3,4,7,8,11,12,15,16 55 degrees, medium length 14,17 65 degrees, long bolts 1,2, 5,6,9,10,13 75 degrees,not sure how to get a diagram to you on what bolts are where, i have one in my book, there are 9 bolts where the rockers are at, from front of engine they are numbered, 17,13,9,5,1,2,6,10,14, on bottom of head by the exhaust manifold is 16,128,4,3,7,11,15, this is from my chiltons book on the same model for a5.0 and 5.7 Liter, hopes this helps
Mar 4, 2007 at 11:20 AM
