1995 GMC C2500 Loss of Steering and Brake and ABS Light
1995 GMC C2500
135,000 MILES • V8 • 2WD • AUTOMATIC
2009RERE
The van turns on and runs fine but when I try to drive, the wheel will not turn easily I thought the problem was with the power steering fluid but it was at normal levels. Then when I pulled out straight I noticed the brakes were very hard to push, and the brake fluid level was fine also. The two problems I noitced at the same time and just the day before I changed the spark plugs and it drove fine, so I think/hope it is one solution but I am not sure of. And i noticed the brake and anti-lock brake lights were on in the dash, does this have something to do with the problem?
Nov 4, 2008 at 2:22 PM
2CARPRO JACK
  • 11,533 POSTS
Possibly. Sounds like the power steering pump isnt working. It runs the steering as well as the"hydro-boost" unit which is your power brakes.Have seen the shafts break on the pumps so that the pump isnt turning internally even though the pulley is.
Nov 6, 2008 at 8:05 AM
